spiderman1
Jan 20, 2014Guide
APT-GET on Readynas Pro
Hi guys, I would like to now how to get apt-get to work on my Pro as I would like to install dmidecode. I have done the following via ssh: READYNASPRO:~# apt-get update Hit http://www.read...
spiderman1
Jan 23, 2014Guide
I have now updated my sources.list file and now when I go about installing dmidecode, I get the following:
What should I do?
READYNASPRO:/etc/apt# apt-get install dmidecode
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
libfontconfig1: Depends: libfreetype6 (>= 2.3.5) but 2.2.1-5+etch3 is to be installed
Depends: fontconfig-config (= 2.6.0-3) but it is not going to be installed
php5-imap: Depends: phpapi-220100525+lfs but it is not installable
Depends: php5-common (= 5.4.20-0rnx1) but it is not going to be installed
tonido: Depends: libfreetype6 (>= 2.3.5) but 2.2.1-5+etch3 is to be installed
Depends: fontconfig (>= 2.4.2-1.2) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
What should I do?
