potatopeel
Jul 17, 2017Aspirant
Apt repositories for 4.2.31 fails
The apt repository for raidiator seems to have stopped working. Err http://www.readynas.com 4.2.31/ Release.gpg
Connection failed
Err http://www.readynas.com 4.2.31/ Translation-en_US
Connect...
- Aug 31, 2017
This is fixed now.
JennC
Jul 24, 2017NETGEAR Employee Retired
Hello potatopeel,
But the ReadyNAS device is getting on the Internet? May I ask why you do it on SSH?
potatopeel
Jul 24, 2017Aspirant
Yes, as you can see from the log it has no problem to fetch data from the debian repositories. The links also don't work from another network and the second poster seems to also have the same issue.
It is not possible to install packages, other than the "apps" built by the community, from frontview so SSH is needed if I need something else.
Netgear has built custom readynas packages and thus there has been a readynas archive where these reside, just as for the newer OS6 as I pointed out. Some of these custom packages are sometimes needed as dependencies when installing new packages.
- JennCJul 24, 2017NETGEAR Employee Retired
