RockyArnold11's avatar
Oct 06, 2017
Archiving Tivo Recordings
Have an RN214 with 4 HDs (8Tb) matched-up with 4 TiVos.  Set it up successfully using full JBOD on each HD in order to maximize storage of videos and not desiring the backup features.  Didn't archive automatically, but for some reason did archive about 7 Tb eventually with parts of each TiVo saved on a single HD.  Again, no automatic archiving, but eventually started up again with another 5 Tb from the set of four TiVos saved on another drive.  The HD used in each case corresponded to the first pathway identified in the DLNA panel. Can't find any reason why automatic archiving does not occur even with Netgear support helping.  Any suggestions appreciated.  Thank you.
  • Marty_M's avatar
    Marty_M
    NETGEAR Employee Retired
    Hello RockyArnold11,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
    The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    Marty_M
    NETGEAR Community Team
  • Marty_M's avatar
    Marty_M
    It does appear you have RN214 with 4 8TB hdd's and each hard drives corresponds to 4 tivo device, the problem is that the tivo is not automatically archiving the files to the NAS. It does appear that you are already in contact with support, I would recommend to focus on the case and if the problem persist after exhausting all the troubleshooting and isolation steps they can possibly escalate the case to higher tier or the engineering department.
    Welcome to the community!
    Marty_M
ProSupport for Business
