dhw
Nov 08, 2015Aspirant
Attempt to update Pro 6 to 4.2.28
I've had a ReadyNAS Pioneer Pro 6 since March 2011; every Sunday, I update the critical systems here at home, and as that includes the ReadyNAS, I check for firmware updates for it (via the "ReadyNAS...
mdgm-ntgr
Nov 08, 2015NETGEAR Employee Retired
You need to unzip the zip file. The firmware image is RAIDiator-x86-4.2.28 in the zip file.
4.2.28 has not been put on the update server yet so a remote update is not possible at this time.
dhw
Ah; thanks. Guess I'm out of practice. :-}
Peace,
david
- bedlam1Nov 12, 2015Prodigy
I have been trying to install the unzipped file to my Pro 4 and continually get the error "Local file upload failed"
Any help will be gratefully received
- mdgm-ntgrNov 12, 2015NETGEAR Employee Retired
This is a different issue then. Have you tried another web browser?
- MatDeyNov 13, 2015Aspirant
My 2100 refuses to upload the file stating that it is not valid
I have tried uploading the extracted file using i.e and also Chrome on Windows 10. Both give the same 'error/warning' message 'Update File is not valid for this architecture'.
It is currently on RAIDiator 4.1.14 [1.00a043]
Do i need to be on a newer version before this can be uploaded?
Any help would be appreciated
Mat
