Dc1981
Nov 07, 2017Tutor
Attempting to update firmware
Hi,
I have looked through the documentation and when I attempt to follow the steps to update the firmware I am struggling at the point of accessing maintenance/download/tftp file download. Under file type dropdown I am expecting to see firmware but am only seeing the following options... Code, Text configuration and 4 SSL options.
Firmware is currently on 5.0.2.33
- Perhaps it will be easier for you use the HTTP File Download option.
- Dc1981TutorHi
Thanks for the reply.
I get the same lack of firmware option under the file type for http as well?.- You don't see a "Select File" option?
