EtherZhang
Mar 16, 2017Aspirant
Auto clean "Recycle bin" on OS6.6 ?
I have looked though this post: https://community.netgear.com/t5/Using-your-ReadyNAS/Can-Recycle-Bin-be-enabled-for-CIFS-and-OS-6-1-2-on-a-314/td-p/856707 And I have successfully enabled the ...
- Apr 05, 2017
So the conclusion of the solution is here:
1. Create file:
/etc/frontview/samba/addons/addons.conf
2. Edit addons.conf according to your existing shares, if you want hide the recycle bin folder, add "." as I did:
[share1] vfs objects = recycle recycle:repository = .Recycle Bin recycle:keeptree = yes recycle:versions = no [share2] vfs objects = recycle recycle:repository = .Recycle Bin recycle:keeptree = yes recycle:versions = no
3. Reload the config file by go to the frontview web interface -> Shares and edit one of your current shares and change something then press OK. The recycle bin will now working on your NAS. Next are how to enable autoclean function for the recycle bin.
4. Create file
/frontview/bin/clean_recycle_bins
and edit it as below:
#!/usr/bin/perl #------------------------------------------------------------------------- # Copyright 2007, NETGEAR # All rights reserved. #------------------------------------------------------------------------- # # exit if( -f "/ramfs/.clean_recycle_bins.lock" ); # open(LOCK, ">/ramfs/.clean_recycle_bins.lock"); # close(LOCK); # while ( -f "/ramfs/spindown" ) { # local $/; # open(SPIN, "/ramfs/spindown"); # if( <SPIN> =~ ":1" ) { # sleep(530); # } # else { # last; # } # } use lib qw( /frontview/lib ); # use Frontview; # # my $fv = new Frontview; # $fv->Account_get_info(); # $fv->Service_get_info(); open(IN, "/etc/frontview/recycle.conf") || exit; my @dirlist = <IN>; close(IN); # if( $fv->{Service}{USER_HOME_DIRECTORY} && # $fv->{Service}{USER_HOME_DIRECTORY_RECYCLE} ) # { # my $path; # my $recycle_max_days = $fv->{Service}{USER_HOME_DIRECTORY_RECYCLE_MAX_DAYS}; # $recycle_max_days = $HOME_RECYCLE_AGE_LIMIT if( !$recycle_max_days ); # my $recycle_max_size = $fv->{Service}{USER_HOME_DIRECTORY_RECYCLE_MAX_SIZE}; # $recycle_max_size = $HOME_RECYCLE_MB_LIMIT if( !$recycle_max_size ); # # foreach my $user( sort keys %{ $fv->{Account}{user} } ) # { # if( -d "$fv->{Account}{user}{$user}{home}/.Recycle Bin" ) # { # $path = $fv->{Account}{user}{$user}{home}; # push @dirlist, "$user!!$path!!$recycle_max_size!!$recycle_max_days"; # } # } # } foreach (@dirlist) { chomp; my ($share, $path, $mb_limit, $age_limit) = split('!!'); if( $age_limit ) { system("find '$path/.Recycle Bin' -type f -ctime +$age_limit -exec rm -rf {} \\; &>/dev/null"); } if( $mb_limit ) { my $dev = `df $path | tail -1 | awk '{print \$1}'`; chomp $dev; my $blocksize = `dumpe2fs -h $dev 2>/dev/null | grep 'Block size' | awk '{print \$3}'`; chomp $blocksize; my $recycle_mb = `du -sm '$path/.Recycle Bin' 2>/dev/null`; chomp $recycle_mb; if( $recycle_mb > $mb_limit ) { my %files; open(FIND, "find '$path/.Recycle Bin' -type f -printf '%p!=!=%C@!=!=%s\n' |"); while(<FIND>) { chomp; my ($name, $time, $size) = split('!=!='); while( exists $files{$time} ) { ++$time; } $files{$time}{name} = $name; $files{$time}{size} = $size > $blocksize ? $size : $blocksize; } close(FIND); my $total_size = 0; my $byte_limit = ($mb_limit * 1024 * 1024); foreach my $time (reverse sort keys %files) { $total_size = ($total_size + $files{$time}{size}); if( $total_size > $byte_limit ) { unlink("$files{$time}{name}"); } } } } # Do a reverse sort so we can rmdir child directories before the parents. open(FIND, "find '$path/.Recycle Bin' -type d 2>/dev/null | sort -r |"); while(<FIND>) { chomp; rmdir; } close(FIND); } close(IN); # unlink("/ramfs/.clean_recycle_bins.lock");PS: You can modify all the '$path/.Recycle Bin' by using your own recycle bin name you used in file addons.conf at the beginning.
5. Create file:
then edit it like this:
share1!!/data/share1!!0!!1 share2!!/data/share2!!0!!1
The last digit "1" I use here represent the how old of the files inside the recycle bin you want to delete when this scrip runs, 1 means older than 1 day, you can set it to 30 then it will only clean files that stays in the recycle bin folder more than one month.
6. Create a Cron by adding a file called "autoclean" or whatever into "/etc/cron.d" folder, then edit the file as below:
0 1 * * * root /frontview/bin/clean_recycle_bins start
Then run
/etc/init.d/cron force-reload
and
/etc/init.d/cron restart
This will allow the scrip to run at every day's 01:00 am and clean the recycle bin according to the "recycle.conf". You can modified it if you know how to write a cron script.
7. Remember all the files that you created here should have 0755 permissions, check this first if you received a error on anything.
EtherZhang
Mar 20, 2017Aspirant
Thanks for the advice, but if I add "#"in front of those 4 lines, I recive this:
root@NAS:~# /frontview/bin/clean_recycle_bins start syntax error at /frontview/bin/clean_recycle_bins line 15, near "my =" syntax error at /frontview/bin/clean_recycle_bins line 49, near "() " syntax error at /frontview/bin/clean_recycle_bins line 53, near ");" syntax error at /frontview/bin/clean_recycle_bins line 101, near "}" Execution of /frontview/bin/clean_recycle_bins aborted due to compilation errors.
So I guess it still need the Frontview library to run the "my" command or something else.
Sandshark
Mar 22, 2017Sensei
"MY" is a standard Perl keyword to declare variables and set their scope, so something else is wrong. But I can find no examples of the "My =" syntax and don't understand why IN is opened once and closed twice. And I can't even find wher the variable IN is used.
As I said, I thought that would work "if it ever worked". I think something else is missing.
I may have to break my NVX out of the closet and see what 4.2.x really contains here.
- SandsharkMar 23, 2017Sensei
OK, so the problem is that the "at" sign has special meaning in the forum software and some important things got deleted from the orignally posted code because of it. Here is clean_recycle_bins from OS4.2.28 with the with the at sign replaced by [AT].. Do a search and replace to put back in the at sign instead of [AT].
Frontview.pmc (compiled .pm) does not live anywhere in OS6.6.x, so all references to it and variables from it are commented out. [AT] dirlist is referenced in the commented code, but that part is just adding the home directories to the list already in /etc/frontview/recycle.conf. I don't think we need use lib qw( /frontview/lib );, either, but it shouldn't hurt to have it and not use it. I have not added any of the OP's other edits, at least assuming the other differences are his and not just changes made in OS4.2.28 vs. whatever he got it from.
I have not tried this myself, though. And as previously stated, I'm not really a Pearl coder, I've just modified a few lines of code now and then using examples I Googled.
#!/usr/bin/perl #------------------------------------------------------------------------- # Copyright 2007, NETGEAR # All rights reserved. #------------------------------------------------------------------------- use lib qw( /frontview/lib ); # use Frontview; # # my $fv = new Frontview; # $fv->Account_get_info(); # $fv->Service_get_info(); open(IN, "/etc/frontview/recycle.conf") || exit; my [AT]dirlist = <IN>; close(IN); # if( $fv->{Service}{USER_HOME_DIRECTORY} && # $fv->{Service}{USER_HOME_DIRECTORY_RECYCLE} ) # { # my $path; # my $recycle_max_days = $fv->{Service}{USER_HOME_DIRECTORY_RECYCLE_MAX_DAYS}; # $recycle_max_days = $HOME_RECYCLE_AGE_LIMIT if( !$recycle_max_days ); # my $recycle_max_size = $fv->{Service}{USER_HOME_DIRECTORY_RECYCLE_MAX_SIZE}; # $recycle_max_size = $HOME_RECYCLE_MB_LIMIT if( !$recycle_max_size ); # # foreach my $user( sort keys %{ $fv->{Account}{user} } ) # { # if( -d "$fv->{Account}{user}{$user}{home}/Recycle Bin" ) # { # $path = $fv->{Account}{user}{$user}{home}; # push [AT]dirlist, "$user!!$path!!$recycle_max_size!!$recycle_max_days"; # } # } # } foreach ([AT]dirlist) { chomp; my ($share, $path, $mb_limit, $age_limit) = split('!!'); if( $age_limit ) { system("find '$path/Recycle Bin' -type f -ctime +$age_limit -exec rm -rf {} \\; &>/dev/null"); } if( $mb_limit ) { my $recycle_mb = `du -sm '$path/Recycle Bin' 2>/dev/null`; chomp $recycle_mb; if( $recycle_mb > $mb_limit ) { my %files; open(FIND, "find '$path/Recycle Bin' -type f -printf '%p!=!=%C[AT]!=!=%s\n' |"); while(<FIND>) { chomp; my ($name, $time, $size) = split('!=!='); while( exists $files{$time} ) { ++$time; } $files{$time}{name} = $name; $files{$time}{size} = $size; } close(FIND); my $total_size = 0; my $byte_limit = ($mb_limit * 1024 * 1024); foreach my $time (reverse sort keys %files) { $total_size = ($total_size + $files{$time}{size}); if( $total_size > $byte_limit ) { unlink("$files{$time}{name}") or system("rm -f \'$files{$time}{name}\'"); } } } } # Do a reverse sort so we can rmdir child directories before the parents. open(FIND, "find '$path/Recycle Bin' -type d 2>/dev/null | sort -r |"); while(<FIND>) { chomp; rmdir; } close(FIND); } close(IN);- EtherZhangMar 24, 2017Aspirant
Thank you so much! I ran this script without an erro, so I think it's working now! I'll wait for one more day and test whether it can auto clean files older than 1 day.
One more question, if I ran this scrip, is the autoclean schedual will automatically go on forever, or I need to add this scrip into a cron, otherwise it will only clean the recycle bin once when I run it mannually?
- SandsharkMar 24, 2017Sensei
Glad I could help, please keep me updated. I didn't end up having to break out my NVX, I just extracted the files from the OS 4.2.28 update package. Once I saw the previously missing "ats", the code made more sense and I was pretty sure that was the key.
It will need to be a cron job to keep deleting files regularly.
