EtherZhang
Mar 16, 2017Aspirant
Auto clean "Recycle bin" on OS6.6 ?
I have looked though this post: https://community.netgear.com/t5/Using-your-ReadyNAS/Can-Recycle-Bin-be-enabled-for-CIFS-and-OS-6-1-2-on-a-314/td-p/856707 And I have successfully enabled the ...
- Apr 05, 2017
So the conclusion of the solution is here:
1. Create file:
/etc/frontview/samba/addons/addons.conf
2. Edit addons.conf according to your existing shares, if you want hide the recycle bin folder, add "." as I did:
[share1] vfs objects = recycle recycle:repository = .Recycle Bin recycle:keeptree = yes recycle:versions = no [share2] vfs objects = recycle recycle:repository = .Recycle Bin recycle:keeptree = yes recycle:versions = no
3. Reload the config file by go to the frontview web interface -> Shares and edit one of your current shares and change something then press OK. The recycle bin will now working on your NAS. Next are how to enable autoclean function for the recycle bin.
4. Create file
/frontview/bin/clean_recycle_bins
and edit it as below:
#!/usr/bin/perl #------------------------------------------------------------------------- # Copyright 2007, NETGEAR # All rights reserved. #------------------------------------------------------------------------- # # exit if( -f "/ramfs/.clean_recycle_bins.lock" ); # open(LOCK, ">/ramfs/.clean_recycle_bins.lock"); # close(LOCK); # while ( -f "/ramfs/spindown" ) { # local $/; # open(SPIN, "/ramfs/spindown"); # if( <SPIN> =~ ":1" ) { # sleep(530); # } # else { # last; # } # } use lib qw( /frontview/lib ); # use Frontview; # # my $fv = new Frontview; # $fv->Account_get_info(); # $fv->Service_get_info(); open(IN, "/etc/frontview/recycle.conf") || exit; my @dirlist = <IN>; close(IN); # if( $fv->{Service}{USER_HOME_DIRECTORY} && # $fv->{Service}{USER_HOME_DIRECTORY_RECYCLE} ) # { # my $path; # my $recycle_max_days = $fv->{Service}{USER_HOME_DIRECTORY_RECYCLE_MAX_DAYS}; # $recycle_max_days = $HOME_RECYCLE_AGE_LIMIT if( !$recycle_max_days ); # my $recycle_max_size = $fv->{Service}{USER_HOME_DIRECTORY_RECYCLE_MAX_SIZE}; # $recycle_max_size = $HOME_RECYCLE_MB_LIMIT if( !$recycle_max_size ); # # foreach my $user( sort keys %{ $fv->{Account}{user} } ) # { # if( -d "$fv->{Account}{user}{$user}{home}/.Recycle Bin" ) # { # $path = $fv->{Account}{user}{$user}{home}; # push @dirlist, "$user!!$path!!$recycle_max_size!!$recycle_max_days"; # } # } # } foreach (@dirlist) { chomp; my ($share, $path, $mb_limit, $age_limit) = split('!!'); if( $age_limit ) { system("find '$path/.Recycle Bin' -type f -ctime +$age_limit -exec rm -rf {} \\; &>/dev/null"); } if( $mb_limit ) { my $dev = `df $path | tail -1 | awk '{print \$1}'`; chomp $dev; my $blocksize = `dumpe2fs -h $dev 2>/dev/null | grep 'Block size' | awk '{print \$3}'`; chomp $blocksize; my $recycle_mb = `du -sm '$path/.Recycle Bin' 2>/dev/null`; chomp $recycle_mb; if( $recycle_mb > $mb_limit ) { my %files; open(FIND, "find '$path/.Recycle Bin' -type f -printf '%p!=!=%C@!=!=%s\n' |"); while(<FIND>) { chomp; my ($name, $time, $size) = split('!=!='); while( exists $files{$time} ) { ++$time; } $files{$time}{name} = $name; $files{$time}{size} = $size > $blocksize ? $size : $blocksize; } close(FIND); my $total_size = 0; my $byte_limit = ($mb_limit * 1024 * 1024); foreach my $time (reverse sort keys %files) { $total_size = ($total_size + $files{$time}{size}); if( $total_size > $byte_limit ) { unlink("$files{$time}{name}"); } } } } # Do a reverse sort so we can rmdir child directories before the parents. open(FIND, "find '$path/.Recycle Bin' -type d 2>/dev/null | sort -r |"); while(<FIND>) { chomp; rmdir; } close(FIND); } close(IN); # unlink("/ramfs/.clean_recycle_bins.lock");PS: You can modify all the '$path/.Recycle Bin' by using your own recycle bin name you used in file addons.conf at the beginning.
5. Create file:
then edit it like this:
share1!!/data/share1!!0!!1 share2!!/data/share2!!0!!1
The last digit "1" I use here represent the how old of the files inside the recycle bin you want to delete when this scrip runs, 1 means older than 1 day, you can set it to 30 then it will only clean files that stays in the recycle bin folder more than one month.
6. Create a Cron by adding a file called "autoclean" or whatever into "/etc/cron.d" folder, then edit the file as below:
0 1 * * * root /frontview/bin/clean_recycle_bins start
Then run
/etc/init.d/cron force-reload
and
/etc/init.d/cron restart
This will allow the scrip to run at every day's 01:00 am and clean the recycle bin according to the "recycle.conf". You can modified it if you know how to write a cron script.
7. Remember all the files that you created here should have 0755 permissions, check this first if you received a error on anything.
Sandshark
Mar 25, 2017Sensei
I originally just looked where the other poster said clean_recycle_bins existed. But it turns out that the file in /etc/cron.daily doesn't just point to the one in /frontview/bin, it's a slightly different file. Some of it won't work in OS6 because OS6 doesn't use the /ramfs directory for flags. You could create one or use another directory and some of the added code looks like it will lock clean_recycle_bins so that if it hangs you won't have a bunch of them hanging. But you can't implement the wait for the drives to be spun up because nothing in OS6 creates that flag. If OS6 has a similar flag elsewhere, I haven't found it. I've commented out those parts of the code, too. But there are a couple other small changes associated with not letting the recycle bin get bigger than the specified size that may be needed to make that part work. Once again, the at sign is replaced with [AT].
#!/usr/bin/perl
# close(LOCK);
# local $/;
# sleep(530);
# else {
# last;
# use Frontview;
my [AT]dirlist = <IN>;
close(IN);
# my $path;
# if( -d "$fv->{Account}{user}{$user}{home}/Recycle Bin" )
# push [AT]dirlist, "$user!!$path!!$recycle_max_size!!$recycle_max_days";
foreach ([AT]dirlist)
chomp;
if( $age_limit )
system("find '$path/Recycle Bin' -type f -ctime +$age_limit -exec rm -rf {} \\; &>/dev/null");
if( $mb_limit )
chomp $dev;
chomp $blocksize;
my $recycle_mb = `du -sm '$path/Recycle Bin' 2>/dev/null`; chomp $recycle_mb;
my %files;
open(FIND, "find '$path/Recycle Bin' -type f -printf '%p!=!=%C[AT]!=!=%s\n' |");
while(<FIND>)
chomp;
++$time;
close(FIND);
my $total_size = 0;
open(FIND, "find '$path/Recycle Bin' -type d 2>/dev/null | sort -r |");
while(<FIND>)
chomp;
rmdir;
close(FIND);
close(IN);
# unlink("/ramfs/.clean_recycle_bins.lock");EtherZhang
Mar 26, 2017Aspirant
Thanks a lot! I have added this scrip into the /etc/cron.daily, and will see if it can work automatically.
And BTW there is another mistake of the file '/etc/frontview/recycle.conf' in the original post, the directory should be '/data/blabla' rather than "/c/blabla", like this:
media!!/data/media!!0!!360 media-other!!/data/media-other!!0!!180
Otherwise the scrip will end up cannot find directory.
- FramerVApr 03, 2017NETGEAR Employee Retired
Hi EtherZhang,
We are monitoring this thread and we would like to know of the current status on your end. Please post/update us so that we can check if there is anything that we can do for you.
- SandsharkApr 03, 2017Sensei
That's actually another difference between OS4.x and 6.x, not an error; but I'm glad you caught it.
So, is it working as expected?
- EtherZhangApr 04, 2017Aspirant
Yes it's working but a little imperfect... every time it executing the cron auto-clean job, if the "Recycle bin" folder itself is older than one day, the cron job will delete it too.
It's not a big deal becuase next time you delet somthing the "Recycle bin" will be re-created, but it will lost the hidden attribute which I manually set.
So I changed the folder name into ".Recycle Bin", I will post out all the revised and correct codes below.
- EtherZhangApr 05, 2017Aspirant
1. Create file:
4. Create file
5. Create file:
Then run
and
- SandsharkApr 05, 2017Sensei
Actually, I believe that's the way it works on OS4.x, too. An empty recycle bin is deleted.
Thanks for running with the baton. I think I'll be doing this myself, very soon.
