taglerock
Mar 30, 2021Follower
Auto Power On After Power Failure
Hello. We have been using Buffalo for quite some time now but we have really started to have problems with their units in that they don't auto power on after a power outage, so any time there is a p...
Mar 30, 2021Guru - Experienced User
taglerock wrote:
Hello. We have been using Buffalo for quite some time now but we have really started to have problems with their units in that they don't auto power on after a power outage, so any time there is a power outage we have to send someone out there.
Personally I'd get a UPS. You really don't want any NAS (no matter what brand) to experience an unexpected power cut.
- SandsharkMar 30, 2021Sensei
An UPS is a must, but an UPS won't hold it up for long.
I don't own a 2304, but most ReadyNAS do auto power-on when power is restored, and page 5 of this spec sheet RR2304_RR2312_RN3138 specifically says the 2304 does.
There is still a scenario in which this doesn't help, though. If the NAS is on an UPS and detects that the UPS is on battery power, it will initiate a shut-down. That reduces the load on the UPS battery, which may last until power is restored. In that case, the NAS never sees a power loss and restore, and does not come back on.
While I don't want to discourage you from buying ReadyNAS, if there is another device on the network that can send a WoL when it boots or when accessed remotely, that could help you with your problem, assuming the Buffalo support WoL. This can also be used to cover the situation I mentioned above, assuming that device does not act the same, so you likely don't want it on an UPS.
- StephenBMar 31, 2021Guru - Experienced User
That will work with the ReadyNAS also - if there is an always-on PC (or one which reboots when power is restored) then someone could use a remote desktop software to access it, and send the appropriate WoL packet if the NAS is powered down. That would avoid the need to send someone.
Or as you say, additionally install software that just sends the WoL packet whenever the PC boots.
