drewbyty's avatar
drewbyty
Follower
May 16, 2016
Backup-->Dropbox configuration not working - switching to On automatically switches back to Off
My system is ReadyNAS 102 with firmware 6.4.2.
I would like to use the Backup-->Dropbox feature, but when I click the switch to change from Off to On, it remains On for maybe a second and then switches back to Off automatically. Also the Authroize button never becomes enabled.
Has anyone encountered this problem before have any recommendation on how to fix this? I have restarted the unit several times and still no luck.
Thanks
  • Make sure the NAS has proper internet connection. Check default gateway and DNS server, add 8.8.8.8 (google DNS) to DNS server settings for testing
1 Reply
  • Danthem's avatar
    Danthem
    NETGEAR Employee
ProSupport for Business
