colmosiris
Mar 06, 2016Aspirant
Backup to USB drive fails with unknown error
My ReadyNAS is very full up, and I'm trying to copy stuff of it without any success. First, I was having trouble with those stupid DS_Store files, so I decided to compress the files in order to m...
BrianL2
Mar 08, 2016NETGEAR Employee Retired
Hi colmosiris,
What is the file system of the external USB drive connected to your ReadyNAS? Also, tell us which model and Firmware is running on your system.
Kind regards,
BrianL
NETGEAR Community Team
- colmosirisMar 08, 2016Aspirant
Thanks Brian L.
The file system of the USB drive is FAT32. The ReadyNAS firmware is 5.3.8, and it's a 4-bay ReadyNAS nv+ v2. (Apparently I can update it to 5.3.11, but I don't know if that will make any difference to this issue?)
Sometimes, it just truncates a file that's bigger than 4.29GB (so this appears to be the limit for this USB drive), and carries on, but at other times, it stops. I haven't figured out what the difference is.
What I'd really like to be able to do, and I've no idea if this is possible, is to say to the backup: okay, backup everything you can, and give me a list of the things you couldn't (I imagine because of characters in filenames, or file size), and then I can do them manually later.
Also, I've got another USB drive, which I know for a fact has over 600GB spare on it, but when I connect it up to either of my ReadyNASes (I also have a v1, which I'm actually copying this data to, via the USB drive), they say it has no free space. It would be useful if I could use this drive as well in this process. According to Disk Utility, its file system is "Mac OS Extended (Journaled)".
But what would be really, really useful, is if the backup could actually tell me what the error is, rather than just "unknown", and the system log doesn't SEEM to have any more detail. It just says "Please see log."!!
Many thanks.
- StephenBMar 08, 2016Guru - Experienced User
That's not a problem with the USB drive - the problem is the FAT32 formatting. If you used NTFS, then you could write the larger files.
colmosiris wrote:
... and carries on, but at other times, it stops. I haven't figured out what the difference is.
Have you tested the USB drive? Possibly writes are actually failing.
Thanks Stephen. No, unfortunately I can't use NTFS, because I can't format those on my Mac. Anyway, I can't format this drive as anything other than what it is, as it has data on it.
There's nothing wrong with the USB drive, or at least Disk Utility says so, anyway. (It's the same drive I was copying stuff onto from the other NAS box last week.) Any thoughts on the other USB drive with 600+GB available on it?
My main question, apart from what use is an 'unknown error', is, is there a way I can make the backup process bypass the errors, and just make a note of them, rather than stopping? It's extremely time-consuming this way!
And also, is there a way of copying directly form NAS to NAS, without using an intermediary drive, and without using Rsync, which AFAICT, wants to incrementally backup the whole volume? (Unless that's not true, in which case, how do I do it, please?)
