glenschaefer
Oct 25, 2017Aspirant
Backup to USB drive fails
I have tried to use a Powered Seagate USB drive (Mystorage 3.0) to backup the data folders on our Netgear Readynas 314. The external backup drive has been cleanly formatted with Seagate's Format util...
Icewaterhot
Oct 25, 2017NETGEAR Employee Retired
HI,
You use the NAS UI format USB storage disk is nomarl?
glenschaefer
i tried both.
First i formatted it with native EXT24 format as recommended and it kept dissappearing as a volume. then i formatted using Seagte's own format tool as FAT32.
Same result.
PS: The external Seagate USB drive works fine on several Linux/Windows 10 PC's
