Bains
Nov 13, 2015Guide
Backup using rsync – what options are used
Rsync is a robust Linux file copy program with lots of options http://linux.die.net/man/1/rsync is a great discussion of the features and options. . http://serverfault.com/questions...
- Nov 22, 2015
Sounds like you may be on your way to a solution.
FWIW, I got my ReadyNAS up into operating condition today and have the following to report regarding the rsync command as issued from the GUI
rsync -v -8 --timeout=30 --recursive --links --times --devices --specials --one-file-system --modify-window=1 --owner --group --no-acls --no-perms --exclude CrashPlan --exclude Downloads --exclude Library/logs --exclude Library/Caches --rsh=ssh -o SrticHostKeyChecking=no -PasswordAuthentication=no -p 22 name@host:/SourceShare /data/DestShare
Good luck!
EDITED TO ADD:
I forgot to say that this is Rsync over ssh with the following options
NO - enable compression
NO - remove deleted files on target
I DO have a list of excluded files/folders, but it seems the gui is programmed also to include .snapshots in that exclusion list
Schedule Full backup: "First Time Only"
NO - Remove Contents before
NO - Change ownership
Bains
Nov 19, 2015Guide
Yes
metapaso
Nov 21, 2015Apprentice
OK, so as I understand it, you want to copy a volume or share from within the ReadyNAS, just to make a kind of backup copy that's "isolated" from SMB. Perhaps this method would work, since you are backing up from within the readynas. It would rely only on the Web interface for Local to Local backup. Rsync is not used:
Step 1: On the "Shares" page, create a new share. Let's call this share "MasterBackup".
In the options for "MasterBackup", choose "bitrot protection" AND set "snapshot schedule" for Daily or Hourly depending on how often you think you need a backup. Disable ALL access protocols (rsync itself my not even be needed, but you may want it for later)
Step 2: For each folder or share that you want to back up, create a subfolder in MasterBackup. For example, if you have a share named DesignTeam, then create a folder in MasterBackup named "DesignTeamBak" or something like that.
Step 3: For each folder or share that you want to back up, in the "Backup" page, create a Local to Local backup. Select the SOURCE folder as "Design Team" and the Destination as "/MasterBackup/DesignTeamBak". Set the backup schedule according to your needs, but remember that backing up MORE often than your snapshot schedule is counterproductive because you'll be relying on the snapshots for the real backing up part.
Note: Perhaps someone from Netgear can tell you what options are used for this backup. It might actually be rsync under the hood, but it might just be a plain old Linux copy command "cp". That might influence whether you want to set the "full backup" option to "every time" or only "first time"
You'll need a good recovery procedure in place in case a viral or worm disaster does strike...my recommendation is to roll the snapshots back to a known good snapshot, then plug in a clean external USB drive and copy the known good snapshot onto the clean USB drive. Maybe a couple of USB drives so you are sure you always maintain a safe one.
- BainsNov 22, 2015Guide
Thanks again for spending the time to offer your suggestions.
Let me be clear, there is no ‘if CryptoLocker hits’ in our contingency planning. Instead we have updated our contingency plan to discuss “when CryptoLocker hits”.
What I did not emphasize or explain properly is that we have non-technical folks responsible for the ReadyNAS system at our branch locations. They try hard to meet what they think are the objectives we want (keeping the branch operational) but the result is often not what is optimal. Think about a typical well intentioned person who tries to help by pushing the ‘buttons’ that they know little about.
We expect to have our data scrambled and unusable at one or more sites. Depending on events and email communications we expect that the event will spread to at least five internal sites and possibly HQ. So, using a technical term, the “fit has hit the shan”. I am not concerned with cost but instead a plan that can be followed by the essential equivalent of entry level technicians with low technical skill level.
Our current plan is to isolate the workstations, remove the malware and then fall back to the last good backup and manually recover the data that is not in the backup, Not elegant, probably will cost a couple thousand at each branch for additional labor costs but lots better than paying ransom.
Snapshots are interesting but probably not the right answer for our distributed environment. At this time I have elected to not use them. That may change in the future when I gain more confidence in the implementation.
StephenB has provided a way for rsync to be used internally and not be equivalent to the Linux cp command. We have tested it and it seems to work. It does not do a ‘copy’ but instead does the typical rsync ‘difference’ for files that have changed. We plan to have several cyclical jobs that will enable multiple copies of the data at different times/stages. Restoration seems to work in our test cases.
The process is a little clutsy/nerdy but it does work. It can all be done from HQ with TeamViewer and RAIDar. I would like to change some of the rsync parameters but the Netgear I/F does not allow that.
As I mentioned previously, we like supported solutions – money is less an issue than reasonable support for the integrated solutions. Unfortunately, aside from a great NAS product, the current ReadyNAS environment is more like a toolbox – good solutions for some stuff but not integrated and RTG.
To this point, the Netgear folks have not responded with a technical answer to my initial question on this thread.
My guess is that the information is either ‘secret’ or they are too busy to pay attention to this type of technical questions for their customers or they do not care. The result is the same.
I was/am hoping a software vendor would see this post and offer/suggest their solution that is already integrated with the appropriate GUI – similar to what we find in the Windows environment.
Thanks again for your suggestions.
- metapasoNov 22, 2015Apprentice
Good luck!
EDITED TO ADD:
Thanks. Lot of effort on your part and much apppreciated.
