PegWeb
Jan 06, 2014Aspirant
Backup via FTP Not working - please help
I am trying to backup via FTP. When I do the test connection everything says it connects fine. When i actually try to run the backup job though it doesn't work. I can see it login to the server just f...
Jan 06, 2014Guru - Experienced User
IF you connect to the FTP site with the filezilla client using the same credentials, does that work properly?
The first post shows a connection timeout with FileZilla, so you probably also need to confirm that data transfers from the server to the PC work as expected.
