rodcrit
Oct 28, 2017Luminary
backups from pc failing after upgrade
after installing the upgrade 6.9.0 my backups from my PC no longer work the backups ( 15 of them ) all start and remain in the " in progress" state. in previous version they remained in the " in...
- Oct 30, 2017
For anybody experiencing an issue with backup jobs remaining in "in progress" on SMB timestamp backup jobs, we have posted a hot-fix to resolve that issue, and your system should be automatically updated some time in the next week. If you'd like the receive the update immediately, you can reboot your NAS and it should be updated within 15 minutes.
rodcrit
Oct 30, 2017Luminary
Yes.... you will probably find that if you go to settingts on the backup detail - and go to source - and test connection... you will get invalid user name and password ( Even if you do not have them set up anyway ).
if you do this and find some other report, would be useful for Netgear to know I think.
Kimera
Oct 30, 2017Guide
rodcrit wrote:Yes.... you will probably find that if you go to settingts on the backup detail - and go to source - and test connection... you will get invalid user name and password ( Even if you do not have them set up anyway ).
Not necessarily...in my case I did the Test Connection - was the very first test I did - and the result is OK for each share considered (as posted in other Threads my configuration is a RN314 joined to a Windows AD...and accesses to CIFS/SMB Share on a Server host are OK).
- SkywalkerOct 30, 2017NETGEAR Expert
- KimeraOct 30, 2017Guide
That's great Skywalker!
Do I wake up a little bit too early or is the Hot Fix not yet released officially?
I did a reboot 5 minutes ago (00:55 CEST) and no new software is available: I checked for updates on "Long-Term Support" which is my default, the "Stable" and the "Beta" branches but the message is always the same laconic: "Your system is currently running the latest firmware. Your system does not need a firmware update".
Is there an alternative way (URL) to obtain such Hot Fix (thus being able to install it manually)?
I would love to test it ASAP and report back.
- mdgm-ntgrOct 30, 2017NETGEAR Employee RetiredThe hot fix is installed automatically in the background. It’s not a firmware update.
