skilke
Sep 25, 2014Aspirant
BASH exploit - Shellshock
Hi I have a ReadyNas Ultra 2 and it has version 3.1.17 of BASH installed which has a High risk vulnerability. Can somebody please explain how to patch BASH so that my system is not at risk from...
alexofindy
Sep 26, 2014Aspirant
What is the latest on this? Any official word?
I have 3 systems, an NV+, an ultra 6+, and a 316. All run the latest release software. As best I can tell, all three systems are therefore vulnerable.
I have SSH disabled on all 3 systems; it was previously enabled on the 4.x systems with the enablerootssh plugin, but I ran the togglessh plug in, which seems to have disabled remote shell access. (I assume it stops the sshd process) On the 314, I disabled ssh in frontview.
I will probably load the latest beta firmware releases on my NV+ and Ultra 6+; this apparently fixes the bug. Correct?
What about the 314? I don't wish to install the 6.2.0 firmware since it is a major but non-production release, and cannot be downgraded back to 6.1.9. Should I turn on ssh, and use app-get to update bash as others have suggested? Or, is bash not used on the 314, and thus there is no vulnerability.
Or is simply turning off shell access as I described above sufficient.
I do not have any port forwarding enabled on my router, which should be protection enough, but I'd rather have the extra layer of non-vulnerable NAS boxes.
