skilke
Sep 25, 2014Aspirant
BASH exploit - Shellshock
Hi
I have a ReadyNas Ultra 2 and it has version 3.1.17 of BASH installed which has a High risk vulnerability.
Can somebody please explain how to patch BASH so that my system is not at risk from this vulnerability. I have tried downloading the source, the patch and patching but 1 file did not patch successfully. If anyone can post some step by step instructions it would be really appreciated (as I am not an expert).
Many thanks
K
Many thanks
K
- PKing1AspirantHi, new user curious about any new firmware update for Ultra 4 (4.2.27 with fixes for heartbleed/BASH?).
- egeekAspirantI have confirmed my NV+ (Sparc) is vulnerable when you visit the shares url (but not the admin url). You can test this by modifying the User-Agent string in a browser with some of the code required to exploit vulnerable bash. In this case I used a simple ping command to do it and watched the target machine using tcpdump.
User-Agent: () { :; }; /bin/bash -c "ping -c 5 [ip address]"
I also modified the string to spawn a netcat session back to a listener (reverse shell). Netcat is not installed by default so that did not work. So as an experiment i installed it and found that the default sparc debian package includes the -e option for netcat and made it trivial to open a shell with a fairly simple modification to the User-Agent string.
I tried to update packages and install a newer bash, but I think that the sparc debian packages are not updated yet.
:~# bash -version
GNU bash, version 2.05b.0(1)-release (sparc-unknown-linux-gnu)
Copyright (C) 2002 Free Software Foundation, Inc.
That's all I have done to test this so far..... - mdgm-ntgrNETGEAR Employee Retiredegeek install the 4.1.14 beta
or modify your sources list to use the 4.1.14 repository and update bash using apt-get - egeekAspirant
mdgm wrote: egeek install the 4.1.14 beta
Thanks, I just caught up with the first few pages and have the beta firmware. On to my other devices now....... - egeekAspirantAll good with the beta firmware update.....No responses to my UA string attack or on the shell itself....
NAS# bash -version
NAS:~# env X="() { :;} ; echo busted" /bin/sh -c "echo stuff"
/bin/sh: warning: X: ignoring function definition attempt
/bin/sh: error importing function definition for `X'
stuff - mdgm-ntgrNETGEAR Employee Retired
PKing wrote: Hi, new user curious about any new firmware update for Ultra 4 (4.2.27 with fixes for heartbleed/BASH?).
The 4.2.27 beta firmware addresses this: http://www.readynas.com/forum/viewtopic.php?f=51&t=70385 - schmitzmAspirant
mdgm wrote: schmitzm wrote:
I'm probably running a rather dated version of RAIDiator on our NAS - can't check the version since I shut down frontview pretty much first thing when the news broke. Are there any update prerequisites for the current betas - i.e. requirement for a minimum release level?
What model do you have?
There shouldn't be an issue.
Of course it is a good idea to ensure you have an up to date backup first.
There is a very low chance that this vulnerability would be exploited especially if you don't forward ports to the NAS. That's not to say there isn't a way, but we haven't found any.
However if you are concerned I would turn off port forwards until after updating to the beta with the patch (or a newer release)
My model is a NV+ (v1), firmware 4.1.4. Just saw the beta firmware installed OK on another of that kind - good to know. Backups are reasonably current but I'll make sure to sync everything up again before an upgrade. A bit of a worry is the tedious fsck I'm almost certainly facing on next reboot.
Port forwarding or not is not the issue - having the NAS exposed to a large untrusted internal network is what worries me most. I've added access controls in /etc/apache/frontview/httpd.conf and disabled anything I don't need for now.
You can probably guess that I have enabled ssh access on my NAS - will this be retained on upgrade? Is the enablerootssh addon still available for this firmware?
One last one - is the beta firmware patched to include the upstream patch bash205b-009 or bash205b-010?
Thanks for your help and encouragement! - schmitzmAspirant
wtriba wrote: schmitzm wrote: wtriba wrote: I'd like to install 4.1.14 beta on my NV+. Is there a direct link to download this?
Thanks!
http://www.readynas.com/download/beta/raidiator/4.1.14/RAIDiator-4.1.14-T5
The FW update to 4.1.14-T5 went fine on my NV+ (v1) and all is well. Confirmed shellshock is no longer an issue with this release.
Thank you!
Thanks for reporting your success - while I've got some way towards cross-compiling a 2.05b bash that might work, it's nowhere near as straightforward to be a guaranteed success. The firmware upgrade is sure a safer way! - mdgm-ntgrNETGEAR Employee RetiredSSH access is retained on upgrade, yes.
Your modifications to httpd.conf may be overwritten so you should backup your changes to that. - schmitzmAspirant
mdgm wrote: SSH access is retained on upgrade, yes.
Thanks - the httpd.conf mods I can quickly redo now that I've refreshed my memory on the syntax.
