Bob_Mcbob
Jul 01, 2012Aspirant
Basic Advice
Hi there, I am after some simple advise which I hope you guys can help with. I have tired reading some of the FAQ's or forum topics, but, if i am honest a lot of it is over my head. Heres the situ...
Jul 01, 2012Guru - Experienced User
>>> MAC address xxxxx claims to have our IP address (xxxxx) (duplicate IP conflict likely)
Try unplugging the ethernet cable for several seconds, and then plug it back in. If that doesn't work, try looking at your various devices and see if you can find the one with the offending MAC address.
