dcg13
Jul 18, 2018Aspirant
Best (and easiest?) way to transfer Time Machine backups from Drobo to new ReadyNAS
Hi-
After enough issues with my Mac recognizing a Drobo or Drobo disconnecting itself, I purchased a ReadyNAS.
On the Drobo, I have Time Machine backups from various computers, as well as oth...
dcg13
Jul 19, 2018Aspirant
Thanks MGDM.
Having mounted the .sparsebundle, I tried to move (through Finder) a directory from the backups.backupdb folder on my Drobo, but am unable to-- "The operation can't be completed because backup items can't be modified." Assuming this is due to ownership/permissions, but I haven't been able to find a solution. Any additional advice/solution you can offer? Thanks.
mdgm-ntgr
Jul 20, 2018NETGEAR Employee Retired
Hmmm. Maybe something changed since that article was written.
You're logging in as a user that has read/write access to the sparsebundle?
- dcg13Jul 20, 2018Aspirant
Thanks again MGDM; I really appreciate your patience and persistence.
By logging into ReadyNAS as admin over SMB, I can navigate to the appropriate .sparsebundle and mount it. Yesterday I changed ownership of it (previously owned by root), thinking that would help; it is now owned by my laptop's user ID, and permissions to the Backups.backupdb in the attached image are drwxrwxrwx+
From the article you linked, I then tried to Restore (Disk Utility) from Drobo to the mounted "Time Machine Backups". It fails, giving OSStatus error 22, with "could not validate sizes - invalid argument" error. Here's the setup (below).
Alternately, I get OSStatus error 19: "source volume is read-write and cannot be unmounted, so it can't be block copied"
- dcg13Jul 27, 2018Aspirant
No ideas? That's too bad.
