davesumm
Jul 12, 2017Luminary
Best practise for expansion
It's in the manual I'm sure but I wanted to ask here also (redundancy). I have a RN102 with a single 6Tb disk in XRAID (I know, i like to live dangerously) and i want to upgrade the capacity to 8Tb w...
TeknoJnky
Jul 12, 2017Hero
yes.
insert 8tb in slot 2
wait for rebuild to complete (volume redundant)
remove 6tb
insert other 8tb
expansion should happen automatically, but you may need to reboot if it doesn't
- davesummJul 18, 2017Luminary
Thanks!
Also, I am worried about defragmenting. Syncing all the data from my old disk to the new should write the blocks contiguously, yeah? I hope so!
- TeknoJnkyJul 18, 2017Hero
uh no, it syncs it directly in the same manner it was on the previous disk.
if you are concerned about fragmentation you should run defrag before and after, along with balance.
I'd recommend setting a volume schedule for about once a month for both defrag and balance (I set mine up on opposite weeks so they do not run at same time).
Thanks again. I've set up defrag and balance on a weekly basis, on staggered days.
What does balance do? And what does scrub do?
