Kwilk6
Jun 11, 2016Aspirant
Best way to keep two ReadyNAS's in sync?
Hi All. Trying to find the best way to keep two ReadyNAS 10400's on a local network in sync without any intervention. Is there an app I can load on the NAS's to do this? Or will I need to run some...
- Jun 19, 2016
omicron_persei8 wrote:
If you want an app, you can try BitTorrent Sync. I have never used it, but I think it could help you achieve what you want.Bittorrent sync is normally 2-way.
The Rsync backup jobs are the path I recommend.
omicron_persei8
Jun 19, 2016Luminary
You can use rsync backup job(s) to transfer data from one nas to the other. There is an option to delete the files on the destination if deleted from the source, otherwise, it'd be a cumulative backup.
It's not a continuous sync though, more like a backup, a copy.
Jun 19, 2016Guru - Experienced User
- Kwilk6Jun 21, 2016Aspirant
Giving Rsync a go now. Thanks!
