Kwilk6
Jun 11, 2016Aspirant
Best way to keep two ReadyNAS's in sync?
Hi All. Trying to find the best way to keep two ReadyNAS 10400's on a local network in sync without any intervention. Is there an app I can load on the NAS's to do this? Or will I need to run some...
- Jun 19, 2016
omicron_persei8 wrote:
If you want an app, you can try BitTorrent Sync. I have never used it, but I think it could help you achieve what you want.Bittorrent sync is normally 2-way.
The Rsync backup jobs are the path I recommend.
Jun 19, 2016Guru - Experienced User
Kwilk6
Jun 21, 2016Aspirant
Giving Rsync a go now. Thanks!
