t1000-forever
Jan 26, 2026Aspirant
Best way to swap drives ReadyNAS nv+ v2
I know that my ReadyNAS nv+ v2 is no longer supported, however I would like to use it as a place to store data that can easily be reproduced. I've had it fitted from day 1 with two 3 TB Western Digit...
- Feb 09, 2026
With the help of StephenB, I disabled write cache in the new three drive setup, also opted to disable AFP, NFS, ReadyDLNA and UPnP services while I was at it.
Low and behold, this time Robocopy was able to copy 35+ GB at 200 Mbps to the NAS without any issues! So I now have Robocopy copying a lot of other data to the NAS, my guess is that whatever the issue was has gone.
t1000-forever
Great thanks for the feedback. Good to know that with my approach, I can always fallback to the WD drives if something goes wrong.
The WD drives have always worked flawlessly (and still do today). My aim though here has been to setup the ReadyNAS from scratch, I have had each of the Hitachi drives in a PC to verify them using CrystalDiskInfo. All reported good health, should I still run some tests using the WD Kitfox tooling?
And no, I did not pay attention to the hardware compatibility list. I figured the Hitachi's will work fine in a NAS, as they're old models they must be CMR (SMR had yet to be invented). Not sure though if they were specifically designed for NAS or Desktops, I got them through someone who was selling 8 of them from his previous NAS though. Let me know your thoughts though.
Ultimately, the Hitachi's will either work or not; if they don't I will simply put the WD drives back in the NAS.
Jan 26, 2026Guru - Experienced User
t1000-forever wrote:should I still run some tests using the WD Kitfox tooling?
Up to you, but I always run both a full non-destructive read test and a full write-zeros test before I put a disk in the NAS.
t1000-forever wrote:My aim though here has been to setup the ReadyNAS from scratch
Is there a reason you need to do that? Full OS partition, or something similar?
If not, I'd just expand by adding two of the Hitachi disks.
If you do start over, you will need to use a browser that still supports TLS 1.0. For instance, FireFox with the security.tls.version.min set to 1 (browse to about:config and search for the setting).
After it is set up again, you'd want to install the add-on that adds TLS 1.2 support. The add-on link is:
- https://github.com/rdynsxtrs/r5bin/blob/master/apache2/Apache2_2.2.34-arm-0.0.1.bin
- t1000-foreverJan 26, 2026Aspirant
Let me try WD Kitfox on one of the Hitachi drives.
I've seen performance degrade over the years somehow. So I prefer to start from scratch. Having said that, while creating my backup over 1 Gbps ethernet and SMBv1 I was able to reach 550 Mbps using robocopy for large files.
Good points about TLS support, can definitely handle that. Will look into adding TLS 1.2 support once setup, I doubt there's any tricks to add SMBv2/v3 support?
- StephenBJan 26, 2026Guru - Experienced User
Unfortunately not. There is experimental smb v2 support that can be enabled with ssh, but I have no idea what vulnerabilities it might have.
- t1000-foreverJan 28, 2026Aspirant
First drive successfully completed a full scan and full erase using WD Kitfox. Will do the same for the other two.
