t1000-forever
Jan 26, 2026Aspirant
Best way to swap drives ReadyNAS nv+ v2
I know that my ReadyNAS nv+ v2 is no longer supported, however I would like to use it as a place to store data that can easily be reproduced. I've had it fitted from day 1 with two 3 TB Western Digit...
- Feb 09, 2026
With the help of StephenB, I disabled write cache in the new three drive setup, also opted to disable AFP, NFS, ReadyDLNA and UPnP services while I was at it.
Low and behold, this time Robocopy was able to copy 35+ GB at 200 Mbps to the NAS without any issues! So I now have Robocopy copying a lot of other data to the NAS, my guess is that whatever the issue was has gone.
t1000-forever
Feb 02, 2026Aspirant
StephenB appreciate your help here.
Any thoughts on why the NAS stops being accessible over the network after copying a (small) amount of data? I feel that this issue should be understood and resolved, otherwise I feel I should put back the original two 3 TB Western Digital WD30EFRX drives.
t1000-forever
Feb 09, 2026Aspirant
- StephenBFeb 10, 2026Guru - Experienced User
Just want to add that this is the first time I've seen an issue where disabling the write cache made a difference, so this is certainly unusual.
- t1000-foreverFeb 10, 2026Aspirant
StephenB I have yet to do more testing with write cache enabled again. It's possible that disabling one of the listed services was what made the difference.
