papagrant
Oct 11, 2016Aspirant
Best way to view videos on NAS from my PC?
I am new to NAS and just installed a NetGear ReadyNAS 202 with 3TB of storage in RAID 1. I plan to use it to store mostly videos. What's the easiest way to play these videos on my PC or laptop? I...
Oct 12, 2016Guru - Experienced User
One easy way is to create a shortcut on the desktop to the NAS video share. Click on that to open file explorer, then click on the file to play it (no copy needed).
papagrant
Oct 12, 2016Aspirant
Actually the ReadyNAS simply showed up under Network Locations so that's fine.
Is there a way to secure the music and video folders? I assume this method is using DLNA which seems to have no password capability. If I switch to SMB, is there a way to view the folder in Windows Explorer?
- cpu8088Oct 12, 2016Virtuoso
with pc using windows u may install vlc media player. it is free download.
your readynas should have smb enabled so from windows explorer can access folders
assume u have respective movies under a folder movies in single file or different folders, u may play those thru vlc by opening file or folder to play.
- StephenBOct 13, 2016Guru - Experienced User
First of all, SMB is what Windows Explorer uses. So if you enter \\nasname in Windows explorer, you will see the list of shares that have SMB sharing enabled.
The answer to password protection is a bit complicated. If you have a family PC, then it is not that easy in practice to use SMB passwords for ratings control. You can require a password for NAS access, but it is not so easy to require one password for share A and a different password (or no password) for share B. Plus windows will keep sessions open, so if you've been accessing share A, and then don't log off, the next user can usually access share A with no password challenge.
If you use separate windows accounts for each family member, or if everyone has their own PC, then it is practical to use SMB passwords for this.
A potential workaround is to make some shares hidden. Everyone can still access them, but they'd need to know the path.
