Ajfan's avatar
Ajfan
Bit rot protection error within /var/log/journal/0/system.journal and cannot correct
Hi !
I just got this message on  my RN 4220;
Bit rot protection has detected an error within /var/log/journal/00d31b31fed446b688b7867645788512/system.journal and cannot correct the error.
should I be worried ?
the raid seems fine, all disk are green. no other errors reported.
Any input would be appreciated.
// Aj
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Which firmware are you running?
    That looks odd. That's a log that's rotated after a period of time. I wouldn't have thought it should have bit-rot protection on it.
    Can you send in your logs (see the Sending Logs link in my sig)?
    • Ajfan's avatar
      Ajfan
      Hi !
      we are running firmware version 6.2.4
      Logs are on the way !
      Thanks !
      // Aj
        mdgm-ntgr
        That's very old firmware.
        Do you have a backup?
        I'd suggest getting your volume usage down to about 80-85% then updating to 6.6.0.
ProSupport for Business
