Esso1968
May 20, 2016Aspirant
Bit rot protection has detected within ...
Hi Community, I have a ReadyNAS 3220 with 8 x WD 4001FFSX setup in X-RAID. Firmware is 6.4.2 Status is "Healthy" File shares (SMB) setup on ReadyNAS and separate FTP server transfers files on...
mdgm-ntgr
May 20, 2016NETGEAR Employee Retired
Is there something you need to recover from that backup?
If not, I would do a fresh backup and see if you still get bit-rot protection errors or not.
What do the SMART stats for your disks look like?
Btw we have released a new firmware release 6.5.0.
- Esso1968May 20, 2016Aspirant
The file that is showing bit rot is the base image of a server backup and it has now started to fail image verification in the backup software (which verifies the whole backup image chain every 7 days). If the image chain fails to verify then I won't be able to use it for restores. So I take it there aren't any repair tools that can be run on it?
I will just have to start a new backup. One of the files with bit rot is 800GB, so its quite a lengthy process to start a whole new backup. This all seemed to start around the time I added an extra 4tb drive to the chassis and it took a few days to add it into the array. (maybe just a co-incidence?)
Where do I find the Smart Stats for my disks?
I will upgrade to the latest firmware shortly.
- mdgm-ntgrMay 20, 2016NETGEAR Employee Retired
If bit-rot protection can't correct bit-rot then fresh backups are the way forward unless your backup software has some other way of fixing it. It's clear that your backup software agrees with the NAS units conclusion that there has been bit-rot that hasn't been corrected, so the feature is working as designed.
Can you send me your logs (see the Sending Logs link in my sig)?
The history of the key SMART stats are in smart_history.log in the logs zip.May/may not be coincidence. It would be interesting to have a quick look of the logs.
Logs sent.
