sotoole54
Sep 25, 2012Aspirant
blinking blue light options?
Hi - i have the readynas duo with 1 drive. a week or so ago i lost power and brought the nas back online. for over a week i can't access it via raidar while the power light (blue) has a slow blink o...
Sep 25, 2012Guru - Experienced User
Yes. Though of course your data is at risk - if the OS partition is corrupt, it is possible that there is also something wrong with the data partition.
gibxxi wrote: An OS re-install will preserve your data, but a Factory Default will wipe the whole NAS, so be very careful how long you have the reset button pushed in for when you start up the NAS.
