sotoole54
Sep 25, 2012Aspirant
blinking blue light options?
Hi - i have the readynas duo with 1 drive. a week or so ago i lost power and brought the nas back online. for over a week i can't access it via raidar while the power light (blue) has a slow blink o...
Sep 26, 2012Guru - Experienced User
-you have the correct procedure; you could also manually reinstall the firmware through Frontview (which does something somewhat different).
-tech support via login is what support would use if you filed a case. There's nothing there that you can run.
-Have you looked at the SMART+ stats being reported under health?
-I would backup everything I can from the other folders first, then attempt to extract anything possible from the bad folder (assuming you have no backup). Then delete the bad folder, and do a volume scan. Finally recreate it, and attempt to restore it.
