PredatorVI
Jul 24, 2014Tutor
Bonding multiple NIC's w/ Cisco 3750
I have a new ReadyNAS 4220. I'm trying to bond all 4 1GbE NIC ports to a Cisco 3750G switch. I'm connecting to the management tool via the 10GbE port so the tool connectivity isn't affected by my tw...
xeltros
Jul 28, 2014Apprentice
Can you do a "show vlans" or a "sh vlan-switch" just to see if the vlan 124 is effectively known by the switch and if VTP is well propagated.
You may also send some etherchannel show commands. show etherchannel port-channel for example or a show interface on the ether channel. to see if ports are taken into account.
I would think that everything needs to be on "access" and "trunk" only between switches.
http://www.cisco.com/c/en/us/td/docs/sw ... Trunk.html
Do you have some spare switch to test without impacting production devices ? You seem to have a pretty big network if a 48 ports 3750G is only secondary device... and using a spare switch and a clean config may eliminate some errors regarding the etherchannel config itself.
As far as I saw on google your config seems correct admitting your VTP and Vlans are set properly and that your cables are good too.
For the NAS, my bad, my UTM has a similar interface. I just checked and indeed readyNAS OS doesn't seem to have this setting.
