PredatorVI
Jul 24, 2014Tutor
Bonding multiple NIC's w/ Cisco 3750
I have a new ReadyNAS 4220. I'm trying to bond all 4 1GbE NIC ports to a Cisco 3750G switch. I'm connecting to the management tool via the 10GbE port so the tool connectivity isn't affected by my tw...
PredatorVI
Jul 29, 2014Tutor
I don't have a spare switch...I wish. :) Although as a last ditch attempt, I may reset the switch to factory defaults and start from scratch.
Although, I'm thinking it's a ReadyNAS bonding issue at this point. I tried to revert back to Bonding using "Transmit and Load Balancing" which supposedly requires NO special switch settings. I cleared all LACP/aggregation settings from the switch ports, verified they work unbonded. I then bond them, save settings and then Power Down/unplug/plug-in/poweron ReadyNAS, and nothing.
When the ReadyNAS documentation says that it only supports "dynamic link aggregation", what does that translate to in Cisco-speak?
I'll open a support ticket and see what falls out. I'd love to get using this thing to it's potential, but maybe I'll just have to use the interfaces individually.
