PredatorVI
Jul 24, 2014Tutor
Bonding multiple NIC's w/ Cisco 3750
I have a new ReadyNAS 4220. I'm trying to bond all 4 1GbE NIC ports to a Cisco 3750G switch. I'm connecting to the management tool via the 10GbE port so the tool connectivity isn't affected by my tw...
Jul 30, 2014Guru - Experienced User
Perhaps it is an interaction with another ethernet facility?
Does LACP work if you disable VLAN on the switch?
If you are using jumbo frames, then perhaps try disabling them.
