KillerBob's avatar
KillerBob
Boot issues... (ticket 18011468)
Hi,
I have been using my Pro without any worries for the longest time. I am on FW 4.2.20-T32.
However, yesterday evening, while streaming a film from the NAS, suddenly it all locked up. I tried to get into Frontview, but there was nothing to do, so I triggered a graceful shutdown via the power button on the Pro. Nothing happened, and I eventually had to hold the Power button for 10 seconds, and it shut down. I let it sit for a few minutes, and started it up again. The "NETGEAR" came up in the LED, and then the "bar" started going. However, where it usually goes to the 6 markers for HDs, it just continued to go on and on with the bar, while the fans were running on max. I left it for a few minutes, I tried running RAIDar, but alas. So, I powered it down again, started it up in Boot Menu mode, ran a memory test, and then before running the disk test restarted the Pro, and it ALL worked as usual. No issues, just a normal startup, and now all is OK. WTF?
I have no idea what could have prompted such a situation. I have never seen this before, and don't know what it means when the bar just keeping repeating left->right.
Any ideas?
Bo
  • Hi readynas1985,
    Thanks. I am getting a bit antsy awaiting confirmation that I have not lost all the data since my latest backup, and that it'll all be OK again, so I do not have to restore for 3 days...
    Bo
  • Well, it all got sorted out by Davinder, who just signed off the NAS.
    As it turns out, it was probably backup logs so big, they were preventing a proper boot sequence. I had a few backup jobs, and one of these had a 850MB log. AHe cleaned up the startup and it rebooted just fine. I then went into frontview and deleted all the backup logs.
    I think it would be an idea to prevent this in the future, by limiting how big these logs get???
    I send a BIG thanks to Davinder.
    Bo
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    There are already precautions in place to limit how big the backup job logs get. However in rare cases for whatever reason sometimes the logs aren't truncated and you get this problem.
    If you go to Status > Logs > Download all logs and extract the contents of the zip file that is downloaded you will see disk_usage.log. There is 4GB OS partition mentioned in that log and you can see how full it is.
    As you're running a beta one also can't rule out something going a bit weird with that. Beta releases are normally pretty solid but don't have to pass the extensive QA testing that a production release does. I would suggest you update to 4.2.20-T40.
  • Yes, I figured as much. But, this is the second I hear about in 1 week, so perhaps we have a problem here?
    Anyways, it is all working now, and it did prompt me to invest in a proper backup solution (Ultra 2).
    Bo
  • I agree with mdgm, and recommend you upgrade to 4.2.20-T40, even though this issue has been resolved.
ProSupport for Business
