Ben_III
Mar 04, 2013Aspirant
Boot stuck installing Add-ons ReadyNAS Pro # 20666710
So I have opened up communication with Tech Support (Case # 20666710) concerning my ReadyNAS Pro 4. I have Plex Media Server and more than a couple Terabytes of videos on my ReadyNAS. I installed a ...
Ben_III
Mar 05, 2013Aspirant
mdgm, I just restarted the NAS and booted into Tech Support mode again as you suggested. There is a new internal IP address assigned by DHCP that shows on the ReadyNAS LCD. Previously I had gone into my cable modem/router and forwarded port 23 to the IP addresses that were assigned to the NAS. Is that the correct procedure? Also, the Tech has never asked for my External IP address so when you say to let the Tech know of the IP are you referring to the internally generated one (LAN) or the external one (WAN). I'm not sure if I'm referring to those correctly but hopefully you know what I'm trying to get at. Thanks again
