SabreDrilling
Jul 20, 2014Aspirant
Booting Checking FS
Hi my name is Clive and this is my first Post My issue is with ReadyNAS NV+ on a remote Land Rig which experienced power failure to the device. Now when it tries to reboot the display message = Bo...
mdgm-ntgr
Jul 20, 2014NETGEAR Employee Retired
Did you have the "Disable Journaling" option checked.
If yes, then it could take a long time. Maybe hours.
If no, then it should be faster.
Do you see a percentage on the display?
