SabreDrilling
Jul 20, 2014Aspirant
Booting Checking FS
Hi my name is Clive and this is my first Post My issue is with ReadyNAS NV+ on a remote Land Rig which experienced power failure to the device. Now when it tries to reboot the display message = Bo...
maxblack
Jul 24, 2014Aspirant
mdgm wrote: Every so often when you reboot it will do one as a precaution. It will also do one after an unsafe shutdown.
Well "every so often" is not very often at all in my case. I looked in my most recently saved-out System_log.zip file from a couple weeks ago and found fs_check.log. It says a check was done in April 2010 due to a dirty dismount, and again in October 2011. Yikes that's not very often! :?
