DarrinJH
Mar 05, 2017Aspirant
Booting sticking 99%
I have a NAS with 3 bays used, I have taken out a drive of another Netgear NAS I am upgrading and placed it in the spare slot, I looked on the volume information and it give me 2, the correct 1 with ...
- Mar 07, 2017
Solved, reinstalling the OS worked. I believe is was the AntiVirus that was the problem. Thanks for the help. Darrin.
mdgm-ntgr
Mar 05, 2017NETGEAR Employee Retired
This is not an issue with the firmware on the internal flash so doing USB Boot Recovery is pointless. USB Boot Recovery is not a "magic" fix to any and/every problem but rather something that is rarely, but sometimes appropriate to use.
Do you have a backup of your data?
- DarrinJHMar 05, 2017Aspirant
Hi,
No I do not have a backup of my data, stupid I know but I did not have 4TB lying around. According to the Raidar the disks are good but the status is 'Management service is offline' I do have apps running on the server MySQL, Anti virious and PHPAdmin, I thought using USB recovory would remove them if they are the problem.
Thanks
Darrin.
- JennCMar 06, 2017NETGEAR Employee Retired
- DarrinJHMar 06, 2017Aspirant
Hi JennC,
Yes, tried that yesterday, it checked the filing system and that was ok. I tried 1 disk in and it still stuck, Next I'm going to reinstall the OS. I do have a question, if I put an unrelated disk in and performa factory reset and then put the already configured volumes in with the box recognise the Volume?
Thanks
Darrin.
- DarrinJHMar 07, 2017Aspirant
