DarrinJH
Mar 05, 2017Aspirant
Booting sticking 99%
I have a NAS with 3 bays used, I have taken out a drive of another Netgear NAS I am upgrading and placed it in the spare slot, I looked on the volume information and it give me 2, the correct 1 with ...
- Mar 07, 2017
Solved, reinstalling the OS worked. I believe is was the AntiVirus that was the problem. Thanks for the help. Darrin.
DarrinJH
Mar 06, 2017Aspirant
Hi JennC,
Yes, tried that yesterday, it checked the filing system and that was ok. I tried 1 disk in and it still stuck, Next I'm going to reinstall the OS. I do have a question, if I put an unrelated disk in and performa factory reset and then put the already configured volumes in with the box recognise the Volume?
Thanks
Darrin.
DarrinJH
Mar 07, 2017Aspirant
