kairs
Jun 16, 2017Aspirant
Booting stucket at 99%
My ReadyNAS is stucked at 99% at boot time, if I press the button on the front I can see that it is trying to run/load fvdropbox.service .... ----------------------------- I have tried telnet: ...
mdgm-ntgr
Jun 16, 2017NETGEAR Employee Retired
To use the boot menu you'd press and hold the reset button, turn the NAS on, keep on holding the reset button till you get a boot menu message. Then release the reset button and use the backup button to scroll through the different boot menu options.
- kairsJun 16, 2017Aspirant
I did not understand that I needed to release the reset button, before selecting the bootoption with the backup button.
Now I could select reinstall OS.
RAIDar shows: System starting up...
But it now seems to be stucked at booting and the LCD display shows "upnphttpd.service ..."
The admin password has been changed to default, so I guess the OS was installed.
