kotten
Mar 09, 2013Aspirant
Both x-raid and single disk
I have a Ultra 4 with x-raid with three 3TB disks. This config works fine but now i want to use the fourth slot that is empty today so i installed a 2 TB disk in the empty slot. My hope was that i ca...
kotten
mdgm wrote: X-RAID2 only allows one volume. To expand your volume you would need to add a 3TB or higher capacity disk.
Is it posible to use raid5 instead of x-raid? I mean if this will allow me to add my 2 TB disk?
or if i attach it to the usb port mayby
