kotten
Mar 09, 2013Aspirant
Both x-raid and single disk
I have a Ultra 4 with x-raid with three 3TB disks. This config works fine but now i want to use the fourth slot that is empty today so i installed a 2 TB disk in the empty slot. My hope was that i ca...
mdgm-ntgr
Mar 09, 2013NETGEAR Employee Retired
You could switch to using Flex-RAID but that would require a factory default (wipes all data, settings, everything) so you would need to backup your data before doing this. When you initiate the factory default there will be a 10 minute window in which you can open RAIDar, click Setup and choose the RAID mode.
