kotten
Mar 09, 2013Aspirant
Both x-raid and single disk
I have a Ultra 4 with x-raid with three 3TB disks. This config works fine but now i want to use the fourth slot that is empty today so i installed a 2 TB disk in the empty slot. My hope was that i ca...
kotten
Mar 11, 2013Aspirant
I have now done the new flex-raid array and still i only can use my three disks. In raidator i can see all four disk but in the webinterface under volume i only see the three raid5 disks.
Can it be that this nas cannot have more then one raidset at the same time?
I have NOT tested like Stephen said, install all disk first and then let nas create a raid5 of the three disk and then i mayby can let the last disk be my single disk.
I did like you said mdgm, but that didn´t work.
Is there someone here that have really set up two different raidset on this nas?
