Gonzo_already_i
Jul 08, 2015Aspirant
BTRFS & LVM
Hi, I was very excited when I realised, that Netgear is now using btrfs. Mainly because it would help a lot when changing disk in a raid0 without the need of destrying the complete raid. (I dont ...
Gonzo_already_i
Hi mdgm
No, no. I'm not sure, but can't btrfs use logical partitions for building a raid? For example, use sda2 + sdb2 + sdc2 to build a raid-n?
yes, eactly. Every time when expanding my NAS's (all bays filled), I'll have the problem, that I have to complete restore them from Backup.
With Btrfs it would be possible to empty one of the disk ( there must be enough space left on the Raid), take it out of the raid, and mount a bigger one to it.
This may be, I'm not that "linux expert". ;-)
yes, I heard about it. But may be, it will become stable some time.
And because I'm not using raid >0 (didn't need to ensure 100% data access) raid 0 would be quite fine for me... :-)
(okay, yes, there may exist some other users, which have to rely on Raid5/6)
[/quote]
That's right, may be next week .... ;-)
Regards
mdgm wrote: What kind of RAID-0 volume would you want? A separate one for each disk?
mdgm wrote:
Swapping disks out isn't meant for backups. It's meant for replacing a dead disk or a disk you no longer wish to use (with a higher capacity one).
mdgm wrote:
I think you meant md raid not LVM RAID. We are not using LVM. OS4 used EXT4 on top of LVM on top of md raid. Now we use BTRFS on md raid.
mdgm wrote:
While the BTRFS filesystem is stable, BTRFS level RAID is still quite experimental (especially RAID5 and RAID6) in my personal view and I would not trust it. Whereas md raid has been around for over a decade and is very mature.
mdgm wrote:
As for what we will do in the future you will have to wait and see.
[/quote]
Regards
