fwdnetad
Jun 05, 2016Aspirant
btrfs command not found
I am trying to use the SSH command to stop a balance. I thought the command was as follows: btrfs fi balance cancel /data But when I try to run that command I just get: -bash: btrfs: comm...
Retired_Member
Jun 05, 2016https://btrfs.wiki.kernel.org/index.php/Manpage/btrfs-balance#SUBCOMMAND
The correct command is:
btrfs balance cancel /data
Make sure you know what you're doing and doing it for a good reason before doing that.
fwdnetad
It worked. Thanks.
