koanit
Dec 06, 2016Follower
Can´t get an IP for our RND2150v2
We have an old NetgearRND 2150v2 and he cant get an IP from the Router. Do you have any idea what we can do?
- Dec 06, 2016
Do you know what firmware the system is running (RAIDar should tell you)?
Can you reach the NAS admin page, or is it using an IP address that is not on the current subnet?
Dec 06, 2016Guru - Experienced User
FramerV
Dec 09, 2016NETGEAR Employee Retired
Hi koanit,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
