AndyWheatcroft
Sep 08, 2018Aspirant
Can I change RAIDiator 4.2.31 temperature limits?
I have a ReadyNAS Pro 6 running RAIDiator 4.1.31 which I recently upgraded the disks to 3GB Seagate ST33000650NS drives. (These are supported drives.)
I run disk scrubing once a month and somet...
Sep 08, 2018Guru - Experienced User
There might be a way with ssh, not sure.
But I'd open the chassis, and see if dirt is blocking the rear chassis fan first.
- AndyWheatcroftSep 08, 2018Aspirant
I am hoping that there is a way to change the value for the disk temperature limits using SSH.
I will check the fan to verify no blockage but I replaced the case fan less than a year ago with an ultra quiet one that everyone recommended.
