CartMan9000
Oct 29, 2014Aspirant
Can I read DISC coming from old RND 2110?
I have sold the old RND 2110, I kept the harddrive and I have a few files on it that I would like to copy to my PC. There were only 1 drive in it, a 1 TB drive that is OK! Is it possible to read th...
vandermerwe
Oct 29, 2014Master
Don't put the drive in the 102 if you want to get data off it.
Is the duo a v1 or a v2, you can use this guide or tell us what the firmware on it was?
http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
If it is a duo v1 you should be able to read the disk using linux reader on a PC:
http://www.diskinternals.com/linux-reader/
If it is a v2 you should be able to red the disk by mounting it on a PC with a linux operating system.
