CartMan9000
Oct 29, 2014Aspirant
Can I read DISC coming from old RND 2110?
I have sold the old RND 2110, I kept the harddrive and I have a few files on it that I would like to copy to my PC. There were only 1 drive in it, a 1 TB drive that is OK! Is it possible to read th...
Oct 29, 2014Guru - Experienced User
Was the duo running with 2 disks? If so, you need to use disk 1.
Also, you should be seeing more than one partition. Are you?
