CartMan9000
Oct 29, 2014Aspirant
Can I read DISC coming from old RND 2110?
I have sold the old RND 2110, I kept the harddrive and I have a few files on it that I would like to copy to my PC. There were only 1 drive in it, a 1 TB drive that is OK! Is it possible to read th...
CartMan9000
Oct 31, 2014Aspirant
vandermerwe wrote: Had you put any data on the disk in the 102 ( I mean the disk that was reported as a volume and that you have now removed)? If there was no data on it, you should have factory defaulted with both disks in. This would then wipe both disk and setup a raid volume.
Does the GUI now show the disk as a volume?
The extra old disk HAD data but I "DESTROYED" it, there were two volumes in the GUI - but after that nothing happened, thereafter I ran the boot default settings, now the entire volume is visible in the GUI
