CartMan9000
Oct 29, 2014Aspirant
Can I read DISC coming from old RND 2110?
I have sold the old RND 2110, I kept the harddrive and I have a few files on it that I would like to copy to my PC. There were only 1 drive in it, a 1 TB drive that is OK! Is it possible to read th...
vandermerwe
Nov 01, 2014Master
Well what do you see on the volume tab?
Is there 1 volume?
What is its size?
What does it say on the left side, does it say Raid 1 or not?
Are all the disks blue with green lights? How many disks are shown?
What does it say under the images of the disks?
Does Xraid on the right have a green light under it?
Do you have 2 equal size and tested disks with no data on them that you can put in the 102 and do a factory default? Sorry but I have lost track of which of your disks have data on them, which you have wiped, which are in the 102 now and which were in the 102.
Is there 1 volume?
What is its size?
