Roaders
Mar 13, 2016Aspirant
Can I remove a disc from a flex-raid volume
Hi All I had a volume disk die on me a week or so ago so I pulled it out, stuck a new one in and the volume rebuilt - all good. I took the old disc out and put it in my desktop and ran the WD...
Roaders
Mar 14, 2016Aspirant
I have a ReadyNas 314 with Firmware 6.4.2
Mar 14, 2016Guru - Experienced User
Thx.
You'll either need to live with the larger array, or do one of the procedures below:
(a) do a factory reset, and restore the data from backup
(b) destroy volume, remove the disk, create a new volume, and restore the data from backup.
With (b) if the apps are installed to this volume, you'll need to uninstall them first, and then reinstall them after the new volume is created.
